Which dino for the Auto-RX?
Washington
I'm going to try the A-RX in my Chevy 2500HD with the 8.1 liter engine. Is there any oil which will work better than the next during the treatment.
Triad, NC
Patman found Schaeffers Synth blend to work excellent. Maybe a little pricey for ARX. WalMart Super Tech has moly, is cheap and probably perfect for an application and rinse cycle.
Las Vegas, NV
I think any oil with a high TBN will help Auto-Rx in the cleaning or in the rinse cycle. I would suggest a "diesel" oil that is API rated SL/CI-4. You can find these oils in the 10W-30 or 15W-40 viscosity for conventional oil. The 10W-30 API SL/CI-4 oil variety is a little hard to find but can be found in the northern parts of the country. I am using Auto-Rx in my wifes 1997 BMW 318i now with Amsoil XL-7500 10W-40. For the Auto-Rx rinse phase next spring I will probably use Pennzoil LongLife 15W-40.
