Originally Posted By: sayjac
Quote:
ok....can everyone explain the differences of the coolants mentioned here.
I thought all extended life coolants contained *some form* of dexcool.
I have read numerous threads and links, but please explain the difference between *why* Peak Global is better then Prestone Extended
I assume by Prestone "Extended life" the OP is referring to Prestone Long Life All Makes/Models, a universal Dexclone. A dex-clone because it contains the active ingredient 2eha like GM formula Dexcool.
And much like going by AF color, going by name alone is not enough information to identify an AF. Long Life can also be a 2eha free Asian P-Hoat like Toyota Red or Mazda Green. So name is also not a reliable way to identify coolant chemistry.
And Peak Global Lifetime is generally considered 'better' here, because it is a 2eha free coolant, that is effective for up to ~5years/100k and compatible with many AF's and cooling systems.
As for 2eha, the active ingredient in Dexcool, it is considered very effective, but primarily because some GM gaskets were not compatible with it, many LIM gaskets failed over time. Actually if one knows their vehicle's gaskets are compatible, 2eha based coolant like Dex and the universals can be effective. Ford is actually moving to consolidate all it's future AF to a dex/2eha based product. And, the universal varients are the most common AF's sold in parts store and places like Wally right now.
Also, agree with others here, no need for WW in pc use.
Note that Ford is moving to a DexCool like coolant. But they are not suggesting to use the new coolant in older Fords that came with G-05. So with respect to DexCool, if it came from the factory with it, stick with it, otherwise figure out what is best for your vehicle other than DexCool.
