quote:
Originally posted by krholm:
A few years ago this was really quite simple but has quickly become much less so. I have a 99 and an '02 Nissan Sentra. The manual for each calls for 50% Genuine NISSAN Anti-freeze coolant or equivalent. It gives no clue as to what an equivalent might be. I've been using the regular 'ol Prestone. I'd appreciate some input from some of you who are 'in the know' as to what I should select for these two cars.
Current Nissan and Toyota use a red colored coolant for which there is no North American equivalent. Honda uses a similar coolant which is green.
As Ray H points out, it is a phosphated no-silicate OAT which uses sebacate as the organic acid inhibitor.
Valvoline suggests using their DexCool type Zerex ExtremeLife, which is no-phosphate no-silicate OAT. Texaco Havoline and Prestone Extended Life are the same type of coolant, all of them containing sebacate and 2-EHA (2-ethylhexanoic acid). The Japanese do not use 2-EHA.
Another option is the G-05 that Daimler-Chrysler and Ford use. This avoid the 2-EHA, which Honda specifically excludes in their recommendations. As a result, Valvoline recommends G-05 for replacing Honda’s version of the coolant Nissan and Toyota use.
The DexCool type coolants offer longer life. The G-05 avoids 2-EHA, which is a plasticizer, and G-05 handles cavitation better, which means if you fail to keep your system topped off your chances of a problem are less.
Ray H also correctly advises you to flush, flush, flush out the old mix of Nissan and Prestone and refill with distilled water and the coolant you choose. Keep a jug of 50/50 mix for refill
I converted an older Honda to DexCool three years ago and have had no problems at all. I will moving my 2002 Toyota over to DexCool next spring.
