Times have changed here in BITOG world. I was sure that a majority of responses would be based around picking the filter with the most pleats, which would be the one on the left. But if you look closer to the pleats, the inner pleats are the closest [around the inner tube area].
There has been a prevailing opinion dating back to the mid 1990’s when the first oil filter study was posted on the Internet that the more pleats that an oil filter has the better. The rationale is that the filter with the most pleats equates to the total amount of filter material (surface area) in the filter and it will be great providing better filtering. I have disagreed with this opinion from the first time I read the Mopar filter study.
As I’ve posted before, the more pleats [exterior, outer circumference, oil input side] that an oil filter has, the tighter the interior [inner circumference, oil output side] pleats are together thus restricting oil flow; especially when oil is thicker and not at operating temperature.
The filters from left to right are: Toyota OE (Denso), Fram EG (before 4/11), and Fram EG (after 4/11). The new Fram EG (after 4/11) looks the same as the Purolator Classic oil filter with the same filter material, plastic endcaps, and made in the USA; Purolator glues a piece of fabric on both ends for better sealing inside the cartridge container.
