- Messages
- 238
- Location
- Girard, Ill
Going to use Amsoil in my new vette! I do not drive it in the winter, just sspring, summer and fall. Which oil[Ams series 2000-0w-30[ or Ams[10w-30 syn] would offer the most protection and less wear?
quote:I hate to tell you but I will probably drive only 3000-3600 miles per year so I will change oil annually!
Originally posted by Pablo: I honestly think the wear will be about the same. I would go with the 10W-30 and pocket the change. What OIC (oil change interval) are you planning on?
quote:I'm not sure if GM would honor the warranty with this oil.
Originally posted by TooSlick: Since you hardly drive this car, I'd run the Amsoil Series 3000, 5w-30 diesel oil,which contains higher levels of rust/corrosion inhibitors. That is typically what is recommended for Mercury Marine inboards, which are the same family of engines. My neighbor runs the Series 3000, 5w-30 in a 37" SeaRay with twin, 454 inboards and it works fine. I'd test the oil once a year and probably run the same oil for 2-3 years; only changing filters every six months.
quote:There shouldn't be a difference between this and any other Amsoil product in terms of warranty. It was primarily formulated for diesel engines but was designed as a "fleet" oil and is safe for gas engines as well. I use their 15W-40 in my passenger car.
Originally posted by yankees1:quote:I'm not sure if GM would honor the warranty with this oil.
quote:
Originally posted by mdv:quote:There shouldn't be a difference between this and any other Amsoil product in terms of warranty. It was primarily formulated for diesel engines but was designed as a "fleet" oil and is safe for gas engines as well. I use their 15W-40 in my passenger car.
Originally posted by TooSlick: Since you hardly drive this car, I'd run the Amsoil Series 3000, 5w-30 diesel oil,which contains higher levels of rust/corrosion inhibitors. That is typically what is recommended for Mercury Marine inboards, which are the same family of engines. My neighbor runs the Series 3000, 5w-30 in a 37" SeaRay with twin, 454 inboards and it works fine. You have my curiosity up concerning this 3000 series oil! I will start a new post and see what others think! Thanks for the info! I'd test the oil once a year and probably run the same oil for 2-3 years; only changing filters every six months.
quote:They have benefits in terms of time as well. Considering that the Series X000 oils have a heavier additive package, they should be able to stand up to short trips over a longer time period as well. Since this car won't be driven in the winter, the extra rust and corrosion inhibitors can be a benefit as well.
Originally posted by buster: If your only going to change it once a year, wouldn't it be better to just go with M1? Save a little $$. Amsoil's benefits really are the long drain.(in mileage terms).
quote:Yep, the 03 M3s now specify 10w60. I've been told that in Canada the BMW dealers charge $150 for oil changes now!
Originally posted by Spector: Didn't we recently see a post on this board (perhaps another topic)) that new M3s were using a 0W or 10W 60 weight????
quote:I did forget to mention that during the winter months when I will not drive the vette, I will uncover it and start it up and let it run for ten minutes once a month. Most of my driving will be in hot summer months. SO, should I go for the Ams 10w-30 which should give me a little more protection in the summer or go with the 3000 series oil[5w-30] which will give better rust protection in the winter but not quite as good protection in the summer?
Originally posted by mdv:quote:They have benefits in terms of time as well. Considering that the Series X000 oils have a heavier additive package, they should be able to stand up to short trips over a longer time period as well. Since this car won't be driven in the winter, the extra rust and corrosion inhibitors can be a benefit as well.
quote:I belive all the E46 M3's specify 10W-60, not just the '03s. Just for clarification, the author of the article you posted has the previous generation of the car. As to comparing the M3 to a Corvette... Drive both of them on a track somewhere and you'll see the difference. Not saying the Vette is a bad car, but they go about their business in entirely different ways. Which is preferable is kinda like the Amsoil vs. Mobil thing
Originally posted by buster: Yeah, the 03's get the 60wt. now. Prior years ran 30wts. I think. M3's are amazing cars, but look, you can buy a new Vette for 40-45K, (10k less then a M3) and it will match it in performance in every category. It also comes with M1 and will NOT cost you $150 to have it changed. That is ridiculous! Is this German "Over engineering" we are seeing?Yankees1, you made a very good choice!
quote:I don't know if I'd do that. Unless the oil is run to operating temperature and stays there for a little bit, you will actually introduce more contaminants into the system. You may be creating more problems than you're solving. Regarding the two oil's, I would think it's kind of a tossup. Just looking at spec sheets, the 10W-30 offers a slightly thicker film, but I suspect the Series 3000 5W-30 has a much higher film strength and greater resistance to high temperature oxidation due to the higher ester content. Maybe one of the Amsoil reps here can the HT/HS numbers? [ January 08, 2003, 10:31 PM: Message edited by: mdv ]
