Originally Posted By: Garak
Of course, the average person would be fine with 10w-30. And no one said that 0w-20 is perfectly acceptable for all engines under all conditions, either; you, however, get dangerously close to stating that about 10w-30, and that's certainly not the case. The 10w-30 you run is decidedly too thin for many applications, yet its cold weather performance leaves much to be desired, at least in certain climates. Try some unaided starts up here in -40 with 10w-30. It won't be a lot of fun. Or, run it in a diesel calling for a high HTHS oil, and see if an ILSAC 10w-30 is actually thick or how much is just a perception.
The root of the problem is the Corporate Average Fuel Economy (CAFE) agency. Once well get rid of that outfit, we can get rid of thin oil.
All fine and good if you can post credible information that shows xW-20 oils have caused problems with the engines which specify its use. Until that point in time, it is much ado about nothing--as with many things on BITOG. Far too many vehicles (read this as millions) which have used xW-20 all their mechanical lives and just keep on going. My experience using xW-20 has been nothing but positive and I subjected my FX4 to conditions that would have created a problem if one was to be had.
