Back again. Contrary to some folks' assumptions, I haven't abandoned this thread. Was just unable to read or post the past few days.
This thread was originally posted in the HDEO forum, but it seems a moderator mistakenly moved it to Motorcycles, as "wet clutch" appears in the title. I thought "not for wet clutch" meant "contains slippery friction modifiers," so I decided to title it this way. Please see Richard Widman's useful paper on selecting oil for classic Corvairs and other cars (read the part about avoiding motorcycle oils) for a discussion of friction modifiers, friction coefficients, and wet-clutch compatibility. (
Cujet, this may a dress your uncertainty.)
I basically want a synthetic HDEO (either a 30 or 40 multi-grade would be fine), containing friction modifiers, for use in a garden tractor, similar to what BITOG member FrankN4 discussed here:
I was able to get my hands on 2 gallons of 10w-30 Rotella T HDEO. At $10 a gallon, it is one of the few oil bargains left out there. I'm planning on using this in a 22hp Kawasaki liquid cooled V-Twin, a 17hp Kawasaki air cooled single (JD Garden Tractors) a 11hp Briggs single, and a 5 hp...
bobistheoilguy.com
He says:
"I use synthetic 10W-40 motorcycle oil in my lawn tractor ... The 100C cSt is 13.9 which gives good protection up to an oil temperature in the 245-250F range. The ZDDP is 1340. HTHS is 4.44. There are special anti rust, anti wear, anti foam, antioxidants, and detergents.
I do wish it had friction modifiers, and I understand why a motorcycle oil can't have friction modifiers, and
I may eventually go to a blended oil with a good dose of friction modifiers."
He then suggests a custom blend:
"2/3 M1 10w-30 HM 1/3 M1 15w-50 EP cSt 40C= 92.5 CsT 100C= 13.55 HTHS= 3.9 VI= 149 PHOS= 1047 ZINC= 1065 MO= 89.5 B= 246 Great pump-ability, great high temperature performance, great anti wear, and FM."
Seems like a reasonable strategy. Generally, however, I prefer not to play chef with motor oils, as I'd rather depend on the manufacturer's expertise and reap the full benefits of an additive package. Thus, I was wondering if there exists a HDEO (30 or 40 multi-grade) containing friction modifiers.
Thanks for the input, everyone. It is appreciated. Perhaps the moderator who moved this thread could move it back to the HDEO forum? (Not the small engine forum, as it's more broadly applicable than that.)
