2015 Ford Explorer P.I. with 3.7 V6. Oil leaking from the front of the engine but not the main seal. You can see oil just on the front 2 bolts but back from there everything is dry. Oil pan gasket RTV going bad?
You might have to drive it to see if it’s fixed. Thermal cycling will be the true test. You may get some residual oil for a while.No that's the block. Checked those bolts and they were quite loose. Tightened them and a few others that were loose to specs. Not leaking after a half hour.
Those look like markings from the local auto recyclerWhats up with the letters on the Oil Pan?
I have seen some fleets mark mileage for when services were done like that.Those look like markings from the local auto recycler
Agree, looks like salvage yard marks.Those look like markings from the local auto recycler
Probably to mark all the major pieces so they can track where it all came from in case items get sold in pieces. I bet there is a overheat tab on the block as well.They mark the same part multiple times?
3 places on the valve cover, 3 times on the intake. WTH?
