No zinc.quote:
TITAN GT1 is a revolutionary new product, the first of its kind in the world. Developed in the Fuchs Group’s major R&D centre in conjunction with a German-based research facility, TITAN GT1 is formulated with unconventional base oils and additive chemistry which is unique to the Fuchs Group.
Found on Fuchs SG website product description:quote:
Specific Gravity = 0.87 @ 15°C/typical
Flash Point = 238°C typical (ISO 2592)
Vis @ 40°C = 50mm2/s
Vis @ -30°C = 3200 mPa s
Vis @ 100°C = 8.9mm2/s
Viscosity Index = 160
From the Fuchs SG website FAQ section:quote:
Titan GT 1 is a New Generation Premium Fully Synthetic Engine Oil for all high performance cars with gasoline or diesel engines. First of its kind to feature a 0W20 engine oil without a viscosity improver for high temperature and high shear stability in tropical climate. First environmentally friendly engine oil to be developed from biodegradable base oils and does not contain ZDTP(Zinc) additive. Guaranteed to extend the life of expensive catalytic converters in all modern passenger cars.
quote:
What are the differences between Titan Supersyn SL '5W40 & 5W50' and Titan GT1 0W20?
Titan GT1 0W20 is an ester base fully synthetic engine oil, whereas Titan Supersyn SL '5W40 & 5W50' are PAO & MC (Molecular Converter) base type fully synthetic engine oil. Ester synthetics are more expensive and have better advantages over normal synthetic oils. And is 100%++ better than mineral engine oil.
Titan GT1 0W20 performance level is very much higher: Lower oil's friction drag, higher shear and temperature stability, very high lubricity, the viscosity is lighter/thinner therefore better flow-rate and cooling rates due to higher oil circulation within the engine. Refer to the attached folder or technical specification about the Titan GT1 0W20.
What kind of car are you going to use this in? Are you going to do a VOA and a UOA, or just a UOA?quote:
Originally posted by Ken4:
I finally picked up 4 bottles. Here are the pics:
Front of bottle
Back of bottle
The odour smells exactly the same as Castrol SLX! It's difficult to describe the odour in words, but if I had to describe it, I'd say it's mildly fragrant with light hydrocarbon smell. Colour of oil is amber. And it's Made in Germany!
In addition to a.m. info:quote:
Here is the info I gathered from the link you provided:
My guess would be 3, since it's marketed as a premium synthetic biodegradable ester based oil. It is also unlikely it is polyolesters such as trimethylolproane esters or glycerol trioleate, since these do not fall under the catergory of biodegradable base oils.quote:
Base Fluids
Biodegradable Base Oils for Lubricants
The main 'chemistry' concerning biodegradable lubricants is different types of ester oil, e.g.:
1. Vegetable oil from harvestable raw materials, for example rapeseed or sunflower oil.
2. Semi-saturated, transesterified ester oils with natural fatty acids, for example trimethyolepropanetrioleate.
3. Fully saturated, synthetic esters based on chemical modified vegetable oils or mineral oil, for example Diisotridecyladipate.
Since rapeseed oil is the dominant crop in Europe, it is possible that Fuchs has chemically modified and fully saturated this rapeseed oil to a high performance level. Assuming GC uses FUCHS proprietary base oil chemistry, this would be one reason why GC cannot be produced in the US, but has to be imported from Germany. But GC can be produced in Malaysia, which could possibly mean it can also be formulated from palm oil! Since palm oil is the dominant crop in Malaysia.quote:
The lubricants industry has invested significant sums of money in developing and marketing biodegradable lubricants. Natural fatty oils such as castor oil, palm oil, rapeseed oil, soybean oil, sunflower oil, lard, degras and sperm oil have been used in lubricants for years. They are so-called triglycerides of more or less unsaturated fatty esters. This type of base is biodegradable and, compared to mineral oils, will show excellent tribological qualities (low friction coefficient, good wear protection). Their range of use is limited by lower stability against thermal oxidative and hydrolytic stress and partly inferior cold flow properties. These limits can be improved gradually either with additives, or with the selection, cultivation or genetically modification of new types of plants. With new types of 'High oleic sunflower oils' (HOSO) with an amount of oleic acid of more than 90% it seems possible to formulate oils for higher performance levels.
I can just imagine a sump full of lard on a cold winter morning.quote:
Using Pennzoil 5w20 in the 3.5 HO in my Chrysler, I haven't noticed any increase in engine noise.quote:
Originally posted by Losiho:
Ken, did you notice any increase in engine noise with the thinner cSt oil ?
Rick,quote:
Originally posted by tdi-rick:
'thougt you locals pronounced it
"Liff-go"
Rick.
(ducking for cover)
