Oz,
This will get you more confused ...
The SAE only requires that xw-30 oils sold in the US have a minimum HT/HS viscosity of 2.9 Cp. To meet the European A3/B4 specs requires a HT/HS > 3.5 Cp, which is 20% thicker than the SAE requirement.
That's why most xw-30 oils sold in the US, including the xw-30, Mobil 1 formulations, don't meet the ACEA viscosity specs ....
To confuse you even more, the latest ACEA "A5/B5" spec calls for HT/HS in the 2.9 Cp to 3.4 Cp range.
These are the low viscosity synthetics I have referred to. The current Mobil 1 does meet these specifications.
If you spend about a week reading through the Lubrizol site: 3w.Lubrizol.com this will all be very clear to you. Or maybe your head will just explode
