quote:
Originally posted by TooSlick:
[QB
The 0w-30 and 0w-40 synthetic grades are the wave of the future
TooSlick[/QB]
That's why so many full synth's are reducing the the amount of synth's they are using in their blend now? Like castrol and amsoil are doing?
Another point.. I do many analysis as well, and quite frankly Ted, I don't see much difference between the 10w ,5w ,15w,0w when it comes to comparisions. It's really amazing we even got an engine to pass by 10,000 miles without a synth.(sarcasim there folks) I think you give synth's way to much credit for car engines Ted. There isn't any evidence that a full synth is going to protect better than a blend or mineral at proper intervals, otherwise we'd have more engines in the junkpile than we do now.
Another point I thought was interesting, the analysis spreadsheet provided by bill, looking at the numbers crunched by tweeker on that, it appeared that the 40wt was providing lower wear numbers than any other wt oil. Now on the flip side, the 20w50 was producing slightly higher wear numbers, so this kinda looks like the 30wt oils where somewhere in the middle for wear #'s.
This boils down to a balance between additive packages, and flow properties and given this information, you'll notice that it appeared the flow properties of the 40wt in those instances is the better choice.
One thing to remember, we are talking ppm's and not chucks of metal here, so I have not seen where most all types of oils don't provide good service and there is many more engines out there on mineral oils that have proven more miles than any synth has as to date. I also believe that since the newer specs offered from the newer GF-3 mineral oils, this gap of a full synth vs mineral has dramiticly closed and there fore many oil companies are reducing the amount of full synth in their base oil for cost reasons and joining the bandwagon with castrol syntec. Case in point amsoils latest change in one of their lines.
Here is a copy of tweekers #'s he compiled based on bill's data...
code:
Wear by oil weight: ppm miles ppm / mile
It appears he had factor'd in other things and re calc'd his findings, so here is the new #'s based on wear #'s and not with any additives and such included as was before.
code:
10W/40 272 68730 0.0040
20W/50 96 16440 0.0058
15W/40 302 39755 0.0076
0W/30 293 18000 0.0163
10W/30 2786 137900 0.0202
5W/30 7346 274986 0.0267
5W/20 1266 26420 0.0479
totals 12361 582231 0.0212
notice that this is avgs' and how the thicker hydro dynamic fluids are more incline to produce less wear #'s and how the lower viscosity #'s are showing higher. This is interesting to say the least. This goes along with supporting my theory with fluid viscosity or "film thickness"="film strength".
[ October 14, 2002, 11:43 AM: Message edited by: BOBISTHEOILGUY ]
