When to service rear wheel bearings?
Tennessee
I have a 04 honda civic and there is no recommended service interval for the rear wheel bearings. I currently have 70k on the car and no indications of grease failure. I have removed the dust covers but that is it. What do you guys think? These new cars don't leave you much to fiddle with. Thanks for the help.
Florida, Cape Coral
I can't address Honda wheel bearings. However; most cars use sealed rear wheel bearings. There is no service interval and no way to inspect other than rotating, feel and listen at tire rotation time.
Iowa
+1 And even RWD cars typically have semi-floating axles that use the rear differential oil fill to lube the rear wheel bearings.
Kestas
Staff member
The Motor City
Your model uses a sealed rear wheel bearing. There is no service for this bearing. It is greased for life... replace when it goes bad.
ON, Canada eh?
+1 \:\! And when it goes bad, trust me you will know! ;\)
sneakboxer
Tennessee
Thanks! i'm an idiot. After i started this post i looked up the parts and sure enough they are sealed. I guess i can't fiddle with them. I need to buy an old VW again, valves, points, carburetors, zerk fittings and manual brakes.
