mene
Originally Posted By: JAG
Originally Posted By: Warstud
Thicker oil increases pressure....decreases flow
Not true if neither the oil pump's bypass valve nor the oil filter's bypass valveopens loses since most automotive oil pumps are designed to pump a nearly constant volume of oil per revolution. Assuming no bypass valves are open and we are talking about hot oil (not highly viscous), a thicker oil will cause both higher oil pressure and higher flow rate, since oil pumps lose volumetric pumping efficiency as viscosity drops.
Original poster: how does oil consumption compare between M1 5W-50 and Amsoil ACD? Did you really use M1 5W-50 and not 15W-50? I ask because the former has been very hard to find in the U.S.
Hi JAG, Yes I used 5W50 and not 15W50 it was easy to find until about 1 1/2 years ago then it became increasingly hard to find until it was gone from the shelves we used to buy it at Walmart of all places by the quart and by the gallon; it can still be bought but it has to be ordered by mail it is even hard to find info in the Mobil 1 website but it is there it is one of the Porsche guys favorites it is even approved by Porsche. If I had to go back I'll use 15W50 because of the ZDDP that was lowered in the 5W50. The oil consumption compared with the times when the valve seals were worn with the M1 is about the same perhaps it was a bit lower then but it also was 70K miles ago, nothing to be concerned then or now.
Thanks!
George
Thanks!
George
