Hello, This is my second time asking for advice, have been lurking in the forum and the website for almost a year and have found almost all my answer but a few, I already posted another in the maintenance section and I think this one goes here, I hope I'm right and sorry if I'm wrong. To the point. When should I increase viscosity due to wear? should I go by Mileage?, Age?, Oil pressure?, Roll the dice?, Wheel of Fortune? None of the above?, All of the above?. I have read the motor oil university the engine is very clean, I have run M1 5w50 for the last 300K, oil pressure has gone down gradually over time/millage it burns about 1qt./2500 miles, from experience most of it is through the valve seals and I'll be changing them during the year, right now the engine is using Amsoil ACD (10W30,30) which in turn is the lowest viscosity recommended by the FSM and the pressure is well above the minimum, it runs good, no new noises and is more lively most likely because of less windage and parasitic losses but my main interest is longevity, I'll go back to a heavier oil if it will make it last the most. Your opinion will be greatly appreciated!
George.
George.
