My 1979 Toyota Pickup (brass Core Radiator, Aluminum head, Iron Block) came new with red antifreeze. This was a no silicate formula but I don't think it was an OAT formula. The newer Pink antifreeze is a no silicate OAT formula. I have been using Prestone LongLife in the Toyota with superb results. The radiator in the Toyota is mounted with rubber (insulating) washers. This to prevent the radiator from becoming a battery and promoting electrolytic corrosion.
The OEM radiator did give out at about 150,000 miles about 20 years and the truck is on it's 3rd water pump.
