Hello,
i have a Toyota Prius Hybrid from 2010. The manual says allowed are 0W20 till 10W40 but 0W20 should be used. 5W30 can be used but only if needed and next time 0W20 should be used again.
Change interval is 15000 km or 1 year. I live in germany and i practically only drive short tracks. Under 5 kilometers, stop and go through the city, and im driving conservative to not having a high gasoline usage.
My car has no problems except after the last checkup.
When i got my car back from checkup i was wondering... i constantly had one liter more gasoline usage. With my short tracks i wasnt near the numbers a prius should have anyway... though i could go near that numbers after driving long ranges and resetting the timer when the motor is warm. Though only with short tracks, where the motor doesnt get warm really, its probably not possible to get the lowest consumption.
Anyway... after checkup i had one liter more. And its constant. I checked the receipt and the manual and found that Toyota wants 0W20 to be used. The workshop added 5W30. So im pretty confident the problem can be found in there. Nothing else was changed except the checkup, new air filter and spark plugs.
The workshop boss didnt want to change the oil afterwards, only offered to give me 0W20 the next time for free. He didnt believe my numbers for gasoline usage but the numbers are consistent.
So im at the point to change the oil to 0W20 on my own. Because when i have to pay for 1l gasoline more each 100km then it would be pricy at the end of one year. So i have read a lot about oil now.
Mobil 1 isnt very good with viscosity? Its pretty often used as an alternative in my country because the toyota workshops dont have 0W20 mostly. But now i found someone claimed its 35% heavier at 0°C and 25% heavier at room temperature than TGMO. I checked Royal Purple and its viscosity index sounds similar to the one of Mobil 1 too.
Then i found there are 0W10/5 from royal purple too. But i have read in the forum that the viscosity isnt as good as TGMO 0W20 even with the better numbers. I dont see why these oils can wear better numbers when they arent as good at the end.
So whats correct now? Whats the numbers i should watch at when chosing the oil? Like i wrote... im having a hybrid. The hybrid gasoline motor barely gets warm anyway and mine the more because of the short tracks i drive only. Seldom i drive freeways but it happens too occassionally.
So searching for the highest viscosity index? Somehow finding out the best viscosity at 0°C and around the temperatures in my area? I dont really know what to look for now anymore.
Of course i dont want to crash my motor. Only want to drive with the least gasoline usage.
Is there a table with most oils to check out details like VI and other values fast? I didnt find anything like that though such thing should be known in this forum when it exists.
Thanks!
Thanks!
