Originally Posted By: FutureDoc
Originally Posted By: UncleDave
Almost every OEM does put magnets somewhere. Drain plugs, trans, diff plugs they are all over. Usually not very good ones though.
So if using the "does the OEM do it" logic prevails there is your answer.
If filtermags testing is to be trusted and using one does drop an ISO code its effect becomes very real.
"Most efficient" is one size bracket- they are still effective down to 2 which is bypass territory.
If you can stop the particles before they go round and round through your bearings and parts why not?
For certain places like the diff where it is a closed area without a filter, a magnetic plug makes sense. It is the lowest point (hopefully) and when stuff settles out, then the magnet has a chance to keep something from going back up. However, an oil filter is not one of those applications. It is not the lowest area for something to settle nor does it have a large volume to "filter". Also, the magnets must be removed otherwise the items stay in the engine so to speak and why adding a bunch of magnets to the pan is a bad idea.
Still, you are not doing anything that the filter itself is not capable of doing.
So you think your filter is catching 2-5's really well?
The filter is the one area where all of the oil will ultimately pass through and it makes sense to trap it there.
Of course the fines have then gone through your oil pump to get there, and a magnetic plug may have caught them
If the oil filter does such a good job why are the fines on the can, or drain plug to begin with?
Going to disagree without being disagreeable.
cheap cheap cheap filter helper.
UD
