I was just thinking of the fact that cars that have used dino oil for a long time, and then used syn.oil suddenly, which causes the "crud-seals" to clean-up, which leads to oil consumption/leaks etc...
this happened to me, and the consumption, although very little now, still hasn't stopped 100%..but I'm sure my engine is also cleaner than before.
So, what's better?
a dirty engine which uses no oil due to crud-seals, which keeps using dino, or:
a cleaner engine which has a little oil-consumption/leak due to syn.oil being used?
should I be regretting trying syn.oil for a few times, which started the oil consumption at ca.72k miles, or be thankful that the engine is probably cleaner, despite the "usage" of oil...?
(when i look through the oil fill-hole, all is shiny, and i can read the stamped scripts on the internal parts very easily...i wasn't able to do that before tried syn.oil...)
So, what's better?
