What weight oil for this built Chevy motor.
Suburban Washington DC
Picked this up a few years ago and only put a couple hundred miles on it, so its time for an oil change. No idea what all was done other than what you see here. Would 20W50 be the way to go? I don't expect to drive it below 40°F, and it's hard enough to start below 60° as it has no choke.
Manteno, IL USA
Not my intention to hijack a thread. The point was 5w40 (with the right additives) in a properly built small block will get you pretty far. 5w30, 10w30 5w40, 10w40, and 15w40 will all be good choices based on climate. These are absolutely solid roller. Quite big cams for the winged cars as many tracks they run flat footed
Los Gatos, CA
If you are running a flat tappet camshaft with high spring pressure, run Castrol GTX Classic 20-50.
If it's a roller cam, 10w30 or 10w40 synthetic. Or just about anything. A roller cam does not need a high zinc oil.
Texas
It really depends on how they setup the clearances when they built it.
Without knowing what they are, synthetic 15W-40 with a ZDDP additive would be my choice if you aren't planning to run it in cold weather.
Caldwell Idaho
Wing cars are amazing to watch.
