If only we could get the dealers to read these also.As much as I like Amd and his TCCN videos, not all of them are winners; this one is lackluster, over-simplified statements of the obvious.
Nothing much to learn from this video.
At least he admits he's not a lawyer nor an expert on this topic, and perhaps his best advice is this: "... research it ..." for yourself.
I have said this for a very long time ...
Anyone who wants to actually understand the M/M Act should spend time reading the FTC information; that is the agency that is responsible for interpreting the ACT and implementing the rulings.
https://www.ftc.gov/business-guidance/resources/businesspersons-guide-federal-warranty-law
https://www.govinfo.gov/content/pkg/COMPS-3072/pdf/COMPS-3072.pdf
https://www.ecfr.gov/current/title-16/chapter-I/subchapter-G/part-700
Same!I'm having trouble with AMD as anything except Advanced Micro Devices
Most warranties require arbitration now, not court. You agreed to it in the purchase agreement and its in your warranty manual. Most people are unwilling to follow the process, which in fairness is likely made unduly arduous in order that people give up.I wish it were this easy, but the dealer can deny and the burden is on you to serve him and haul him into court and prove your case. Then you have to convince the judge or jury. If the dealer hires an attorney you’re dead unless you lawyer up. Just saying that’s how it works in America.
To the average person, what does that mean ? If Fram or WIX or (insert any dozen different filter makers here) says the (insert any auto part here) works on my car, we have to put 100% trust in them.The catch folks seem to have is that you still have to use equivalent parts per the manufacturer's requirements.
He's the greatest Toyota mechanic on the face of the earth and if you don't believe me, just ask him !AMD is the name of the guy who runs a repair shop (specializes in Toyota/Lexus products) and has his own YT channel.
It means use the right parts. Parts store filter X is what they show...golden. What the BITOG collective gets hung on is oil grade. Manual/manufacturer says use 0W20...you use 5W40. Engine grenades. Dealer says no dice because you didn't follow the manufacturer guidance. You scream "MAG MOSSSSS". Fine. You'll need to get this to arbitration and hope your case is strong against the manufacturer's experts that the oil wasn't the cause of the failure...Mag Moss doesn't help here because you went outside of the manufacturer's recommended parts (but you'll probably win anyway)..if you used brand x 0W20 that met whatever requirements you'd be golden per Mag Moss.To the average person, what does that mean ? If Fram or WIX or (insert any dozen different filter makers here) says the (insert any auto part here) works on my car, we have to put 100% trust in them.
I always point out when an owners manual says something is "recommended". That's very different than "required". When a company uses recommended, my interpretation of that is it means there are other acceptable or allowable options. Quite often, all one needs to do is see what oil viscosity is allowed or referenced in the owners manual for the same vehicle/engine for other countries. Honda says 0W-20 in US owners manuals while in other countries, that same vehicle can use 0W-20 up to 20W-50 !!doesn't help here because you went outside of the manufacturer's recommended
Regardless you open yourself up for hassle at the dealer level on a warranty claim by not following the manual. Folks that want to deviate should at least understand that.I always point out when an owners manual says something is "recommended". That's very different than "required". When a company uses recommended, my interpretation of that is it means there are other acceptable or allowable options. Quite often, all one needs to do is see what oil viscosity is allowed or referenced in the owners manual for the same vehicle/engine for other countries. Honda says 0W-20 in US owners manuals while in other countries, that same vehicle can use 0W-20 up to 20W-50 !!
ExactlyI always point out when an owners manual says something is "recommended". That's very different than "required". When a company uses recommended, my interpretation of that is it means there are other acceptable or allowable options. Quite often, all one needs to do is see what oil viscosity is allowed or referenced in the owners manual for the same vehicle/engine for other countries. Honda says 0W-20 in US owners manuals while in other countries, that same vehicle can use 0W-20 up to 20W-50 !!
