- Messages
- 6
- Location
- connecticut
I was recently given a 1990 Saab 900 with 200,000 miles. It seems to run fine, but I don't know much about its prior history or maintenance, never mind what type of oil was used and how often it was changed.
I gave it a tune-up and changed the oil and filter. I used Valvoline Maxlife 10w-30 for no particular reason. I'm not exactly mechanically inclined, but I'm trying hard to educate myself. I figured it made sense to use high mileage oil considering how many miles are on the odometer.
I found a quart of dino oil 10w-30 in the trunk so assume that is what was being used for the past few years at least. I have no idea as to condition of the engine, whether it is clean or full of sludge.
I'm trying to figure out what the best type of oil and viscosity I should use taking into consideration the high miles and my local climate; I live in Connecticut.
I was considering using an auto rx flush, but I'm concerned that it might clean away deposits that are actually acting like seals. I was warned that I might develop leaks this way. I've also been warned to stay away from synthetics, again because I might develop leaks since the oil is thinner.
Most people over at saabnet.com seem to agree that older Saabs like thicker oil.
As you can see, I'm quite confused as to whether I should stick with what I'm using or make a switch. Also should I try Auto RX or am I asking for trouble.
If anyone could provide some advice, I would appreciate it.
Thank you in advance,
Louis
[ January 05, 2004, 12:06 AM: Message edited by: lpass ]
