While traveling on interstate 64 to the Virginia beach at 70 mph over the weekend, my 1997 Toyota Previa van equipped with 15" factory alloy rims hit a piece of concrete debris with both driver side's front and rear tires. I did not steer away from it fearing the loss of control of the van. Once getting off the highway and onto route 60 the left rear tire became flat. Thanks *** the air leacked slowly that I did not get strained or rollover on highway.
After taking off the flat tire I saw not puncture of any kind on it. I am not sure if the rim was bent. My coworker suggested the seal between the tire and rim was bad. He said to try inflating the flat tire to see if it still holds air. I have not yet done anything to the flat tire. Should I replace the flat tire with at new one, which means I might have to replace all 4 tires because of All-Wheel-Drive nature? The tires are no more than 2 years old. If the flat tire holds air when I pump it, is it safe to use it?
