My 2004 Crown Victoria has been sitting for a while and won't start.
It's not getting fuel, as verified with a scantool that shows the fuel pressure at 0.2PSI. It has a returnless fuel system.
I have voltage and communication with the Fuel Pump Driver Module because if I try to start it with that disconnected, I immediately get a code P1233 which means that the fuel pump driver module is disabled or offline.
I get no such code when it's plugged in.
I checked the resistance to the fuel pump and I'm getting 1.6 ohms.
I then tried powering the fuel pump with my bench power supply (current limited to 10 amps) and it drops the output voltage all the way to about 7 volts, meaning that at 12V this fuel pump would be taking more than 10 amps so it lowered the voltage to maintain it's 10 amp limit.
The fuel pump fuse in this car is 20 amps.
I checked the fuel pressure while I was powering the fuel pump from my power supply and it went up from 0.2PSI to 0.3PSI. I also did not hear it running.
Does it sound like the fuel pump is bad? Perhaps seized up or has shorted windings?
