- Messages
- 478
- Location
- Deep South
Bobistheoilguy, I need to let you know the results of the gasoline additive I acquired from you. It was the Schaeffers No.131 Neutra product. I purchased an '87 Mitsubishi Pickup new. I don't recall how long it took, but a 'ping' became audible in the engine, especially while under load. The dealer never took much of an interest in it except to advise me to go to a higher octane gasoline. I reminded them that the book says to use regular octane 87. They insisted the book was only a place to begin, or something like that, when, in fact I needed to go to an 89 octane fuel. I carefully studied the advance curves of the distributor, modified a distributor to hold the curve more perfectly, but none of this seemed to help. I then began using the 89 octane, which quieted the 'ping'. I now have 186k miles on that truck, most of them on the more expensive fuel to keep it running quietly. Once or twice I put in the regular, but the 'ping' would be right there when I did. Recently I acquired a bottle of Schaeffers No.131 Neutra. You instructed me to put it into the fuel tank, which I did, never thinking about what fuel I'm using or the original problems of the engine noise. After I burned the treated gas I decided to try the cheaper fuel as an afterthought. I really did not even think about this when you provided the additive to me. I ran the gas tank to near empty and refueled with the cheaper 87 octane fuel it hadn't had in a very long time. NO PING !!! I ran that tank just about dry and have repeated the process and my little 2.0 litre engine is running along better than I can remember it ever doing and it's doing it quietly on the cheapest gasoline. That's a little success story.
Also, on the recommendation of a tribologist I have been running Schaeffers Blend 15W-40 motor oil in the truck and the Schaeffers Blend 10W-30 in a '99 Nissan Sentra GXE I have. This was suggested to me over the full synthetic I was using at the time. Thanks for an excellent product. krholm
krholm
