What can you get a Fram Tough Guard (TG) or a Fram Ultra (XG) for? I'm betting they will be less cost than the Mobil 1 filter.Good point, 20 microns at 99% would be ideal. Preferably for a better price than the Mobil 1.
Can you post a link to this table?If you can direct me to the data I can add it to my comparison table
I don't think USCAR-36 gives a mileage rating spec ... that would be up to Motorcraft, which all they say is "follow the owner's manual" like all the other filter makers.Thank you ZeeOSix for the Motorcraft data! I'll use the 80% at 20 microns as recommended above. I went to the sight and there is no mention of filter life in miles. Does USCAR-36 have any language about filter life?
I've heard this before.The Fram of the time was definitely regarded as the Orange can of death on the web, and no one would be caught dead using it. Not sure where that came from either.
That was many years ago ... things change fast in the oil filter world. Old reputations are sometimes hard to bury because people parrot nonsense for years with no real facts to support it.I've heard this before.
Reputation unearned or well earned?
Motorcraft use to advertise 80% @20u on the Motorcraft website, but that was before USCAR-36 came along. USCAR-36 says the oil filter must be at least 95% @ 30u, which 80% @ 20u may closely equate to.
And here it shows the FL820S (many years ago in 2011) was 93.7% !@ 20u. So it's anyone's guess of what you would rate Motorcraft filters at these days. Guess all you can say it "95% @ 30u or better" based on USCAR-36 spec which is what Motorcraft is going by today.
Thanks. It seems from a link posted above that the Fram ultra synthetic is leading the pack and cheaper than Mobil 1.Fram Extra Guard
Wal-Mart SuperTech which we don't have here in Canada.
Toyota makes long lasting engines with low efficiency filters.
OEM are easy to get and reasonably priced
If their top of the line XP is 60% at 20um, then how can their next down be 95%? Not saying it isn't - I would however be very interested in such a filter but have been lead to believe its something else.
Would you all like to see ISO 4548-12 Oil Filter Lab Testing Comparison, Efficiency & Capacity, Pressure vs Flow, Bubble Point, and Burst?
I have this as a “watched” thread, so if you do happen to start a new one, could you put a note or link in this one to direct followers to the new thread? Thanks!! Yes, no problem I can do that.bobistheoilguy.com
True enough but lack of data doesn't help.That was many years ago ... things change fast in the oil filter world. Old reputations are sometimes hard to bury because people parrot nonsense for years with no real facts to support it.
You can state your case on a topic but don't jump on a guy with a "reply" to issue a lecture. I'm just giving you some friendly advice. Welcome to Bob is the Oil Guy.Tell me where in my reply to you is disrespectful to even mention manners, and what does 82 posts have to do with it.
Well, I've read and posted on this board for 12+ years, and in reality there are less Fram oil filter failures than most other brands reported here by members with photos. Purolator takes the 1st place prize over the last 10 years with all their tearing media issues for years - all though they have seemed to be better in the last few years (lessons learned by them apparently). If you have any better data besides people parroting bad things about them from 20 years ago, please post it up.True enough but lack of data doesn't help.
I could get into car wax as another example.
Or high efficiency natural gas furnaces (if we really want to go off topic).
I'm a numbers person but when the numbers are lacking its hard to trust anything.
After trying a bunch of different filters - I bought 6 different ones although I haven't tried them all yet, I had settled on the Ultra as well. However I have recently decide the Tough Guard might be a better fit for my short OCI. Its the same micron rating, but it does only have a single layer, and it does use fiber end caps. So there are some differences to consider. Unfortunately the TG is not in my 6 samples. Lucky 7 it is.Thanks. It seems from a link posted above that the Fram ultra synthetic is leading the pack and cheaper than Mobil 1.
General PDP Template
www.canadiantire.ca
I asked you a question, a question is not a lecture. And after my question I stated my opinion.You can state your case on a topic but don't jump on a guy with a "reply" to issue a lecture. I'm just giving you some friendly advice. Welcome to Bob is the Oil Guy.
Do you have a link showing the same micron filtration result?However I have recently decide the Tough Guard might be a better fit for my short OCI. Its the same micron rating, but it does only have a single layer
Go look around on fram.com. All the efficiency info is there.Do you have a link showing the same micron filtration result?
Hi Bart 9;Can you post a link to this table?
+1Purolator takes the 1st place prize over the last 10 years with all their tearing media issues for years
I'd probably list it as 95% @ 30μ and flagnote/reference USCAR-36 since that is the spec Motorcraft is calling out these days.I added a Motorcraft FL810A to my oil filter data analysis table at 80% efficiency, 20 microns and 5,000 mile life. Thank you ZeeOSix for the help.
