Gents;
I've finally setteled on using the M1 EP for the published interval (15K or 1 year). So what filter to use?
Interestingly, Mobil's site says "no special filter" or "more frequent filter changes" are required. So, theoretically you could grab a fram or supertech or Advance Auto and go 15K or 1 year on it.
Well, I asked Purolator and WIX what they thought about using their filters for that interval w/ M1 EP and here's what they said:
Purolator:
Purolator does not recommend using any Purolator filter longer than the manufacturer's oil change interval recommendations in your vehicle owner's
manual. While synthetic oil does not break down or "coke out" as natural oil does, the combustion process of an internal combustion engine does not change. That process still puts contaminants into the oil stream, and the
oil filter is still the only means of removing those contaminants. Thus, even with synthetic oils, Purolator recommends changing the oil filter at normal intervals and topping off the oil to maintain proper fill.
WIX said basically the same thing...change more often or it will clog (lost the email, ****).
So, I found some M1 EP filters and bought them instead.
Purolator:
