What kind of oil for an '03 TB 4x4?
New York, USA, North America, Earth
New here, wondering what the experts have to say about oil type, filters and change intervals.
1. What kind of vehicle you have
2003 Chevy Trailblazer EXT 4x4 with 4.2L engine, 137k miles just bought it last month and have put about 1k miles on it so far.
2. What your owner's manual says -- not just viscosity, but certifications (look for acronyms like API SM, ILSAC GF-4, etc.) and change intervals as well.
"As in the chart shown previously, SAE 5W-30 is the only viscosity grade recommended for your vehicle. You should look for and use only oils which have the API Starburst symbol and which are also identified as SAE 5W-30. If you cannot find such SAE 5W-30 oils, you can use an SAE 10W-30 oil which has the API Starburst symbol, if it's going to be 0°F (-18°C) or above. Do not use other viscosity grade oils, such as SAE 10W-40 or SAE 20W-50 under any conditions.
Notice: Use only engine oil with the American Petroleum Institute Certified For Gasoline Engines starburst symbol. Failure to use the recommended oil can result in engine damage not covered by your warranty.
Don't add anything to your oil. The recommended oils with the starburst symbol are all you will need for good performance and engine protection"
I believe it has an oil life monitor dummy light.
3. Where you live
Upstate NY, very cold, snowy winters, moderately warm, but very humid summers (~5 or so 90°F or warmer days in the summer)
4. How you drive (easy? hard? fast? slow?)
Wife is primary driver, takes it pretty easy.
5. What your daily drive is like (short trips? long trips? city? highway?)
Driving is probably about 25% city, 25% highway, 25% rural, 25% suburbs? Lot of shorter trips, but 90% of the time at least long enough for the engine to get up to temp.
6. Whether your car has any known problems
Working out a few things (running under temp, need to change the thermostat), but no engine related problems that I am aware of. Engine purrs along great other than what sounds like an exhaust tick at highway speeds. Pretty sure it doesn't leak or burn anything.
7. If you have any preferences -- synthetic vs. conventional, store-bought vs. ordered online, how long you'd like to go between oil changes, etc. -- or any other info you think might be important, let us know that as well.
I’ve stuck with Mobil1 full synthetic and OEM filter with my newer car and was sort of preparing to do the same with this, but I’m always up for saving money. I assume the previous owner stuck with dino 5W-30. He said he took it in to get the oil changed at 3k miles or a bit more. I’ve changed the oil myself on my other vehicles the past couple years and like to do so in the first good weather of April and the last good weather of October whether it really needs it or not (it usually does). It gets very cold and snowy up here in the winter and I really don’t want to get caught needing a change in January is basically the reason. The TB is for my stay-at-home wife with the kiddo, so not a whole lot of miles, I’m guessing it will see 400-750 miles per month once my wife stops working end of this month. If you can talk me into once per year oil changes at 5-9k miles, I wouldn’t be adverse to that, I’m just a little nervous about going 12 months between changes, regardless of the miles.
Thanks for your input!
Originally Posted By: dparm
You could run Pennzoil Platinum 5w30 and stretch the change interval out to 5-7.5k.
No way.
The 4.2l I6 has a 7 quart sump. I know because Ive owned one since 2004
Ive had several UOA's done on this engine (Im at 142,000 miles now) and you cannot go wrong with any good synthetic oil. Heck, Motorcraft semi syn 5w/30 showed little/no wear numbers after 8000 miles! I regularly run Valvoline synpower 5w/30 and get stellar UOA's at 10,000 miles.
Be sure to run a good oil filter, Ive run Purolators for years on it. You will likely have cold engine piston slap on the 4.2l like the rest of us 4.2l owners. Ive had it since I bought the truck.
Good Luck and Congrats on your new TB!
I never had piston slap when I owned an Envoy XUV for 1 year, interesting to know though.
I noticed a significant difference in the winter when running PP5w30 vs. a bulk dino the dealer had.
It started like it was summer, the lifters quieted down almost immediately and it ran a lot smoother.
It was a very good engine, just wish I would have gotten the Saab version as my interior left a lot to be desired. I had some electrical issues not covered under warranty and got scared so I dumped it. I liked the Saab version looks better anyway.
How are the following Valvoline deals currently on Advance Auto? If you definitely think I should go synthetic I will, but I like to save a couple bucks when I can. They include 5 quarts and Puralator PureOne filter. I realize I'd have to pick up an additional 2 qts.
Valvoline...
Conventional for $18
Durablend for $20
MaxLife for $20
SynPower for $28
IMO, You can't go wrong by using the Oil Life Monitor and conventional oil. Personally, I use Pennzoil Platinum 5W30 and non E-Core AC filter (PF61). Onstar vehicle diagnostics estimates my next oil change based on current driving habits to be 26000. It was last changed at 15000 in April. I use synthetic for peace of mind, and will probably switch to Valvoline after the PP is gone.
Also, You may need an oil that meets GM6094M specs too.
Use a synthetic such as PP, Synpower, etc and go to the OLM, which should be in the 7-10k range. My dad has been doing that with his Envoy since new, and it still runs like a champ.
