I've been looking around at a lot of different oils and ATFs. I think I understand the relationship of viscosity and temperature as it relates to the viscosity index.
I have always thought that a higher viscosity index was better and would flow better than a lower viscosity index fluid, given the same circumstances.
I've been looking at Dex VI ATFs and most all of them have a viscosity index around 150, but if you go to a TES-295 fluid or a clone of it, you'll see a viscosity index around 200.
I thought maybe this was because of the viscosity improvers that different blenders use or maybe somewhat dependent upon the base fluid used.
But then if you go look at Citgo Quatrasyn which uses no viscosity modifiers, you'll see a lower viscosity index at 171.
The Viscosity at 40°C and 100°C aren't too far from each other on any of the mentioned ATFs. I do notice that ATFs with a higher viscosity index generally tend to have a lower Brookfield Viscosity.
I guess I'm asking what the viscosity index really means in practical terms?
Is it something that should be payed attention to in selecting the "best" fluid for your application.
I know that any fluid recommended/approved for a given application will most likely work just fine, that's not what I'm here to debate.
I just want to know what to look for if you're nitpicking for "the best" fluid, after all.... isn't that what we do here?
