Can someone tell me what this round thing is with a vacuum line pointing up? On a 1984 ford F150 302.
Check valve?
Its tied into the egr and purge solinoid.Where does the other end of that vacuum line go to?
This ^. The plastic part in the line is a vacuum delay valve.Looks like a vent from the fuel tank in a closed vented system.
Carbs got too complicated right before fuel injection got popular!Ok, found out it's a temperature compensating valve that regulates the power valve. Reduces fuel shot when engine is hot. Thanks for the replys.
Agree. I think I'll purchase a Holly 2300 2brrl. None of its emissions stuff is working anyway.Carbs got too complicated right before fuel injection got popular!
Fuel shot?Ok, found out it's a temperature compensating valve that regulates the power valve. Reduces fuel shot when engine is hot. Thanks for the replys.
Amount of fuel the power valve allows when vacuum drops.Fuel shot?
ThingamajigIts an old styled inline doohickey
Are you sure about that? Where does the other end of the hose go to?Ok, found out it's a temperature compensating valve that regulates the power valve. Reduces fuel shot when engine is hot. Thanks for the replys.
kind of like a duty cycle solenoid an electronic carburetor.Sounds complicated and borderline convoluted.
Also seems like the kind of thing a computer controlled fueling system could handle much better.
I think I will set about inventing just such a system. Y’all better get ready to be impressed, this is gonna revolutionize the automotive industry!
To a tempurature switch then to intake manifold vacuumAre you sure about that? Where does the other end of the hose go to?
