Originally Posted By: 92saturnsl2
I remember my first vehicle, a 1978 F150 w/ the 400ci V8 would run 1500rpm at 65mph. A buddy's 1969 Ford Ranchero w/ the 302 V8 was similar.
Are you sure about that cruising speed for the truck? If the truck had 31" tires, to be doing 1500 RPM at 65 MPH you'd need a rear end ratio of about 2.15:1 (unless the truck had overdrive).
Optimal cruise RPM varies for each car. Torque peaks have gone up on modern cars, as well as RPM range for engines. Accordingly so have the cruise RPM's and gear ratios. Back in the early 80's many cars had super low (numerical) gears, to keep the cruise RPM's as low as possible to keep the fuel economy as high as possible. Some cars without OD had 2:14 axles, and with OD some cars still had 2.56:1 ratios. Of course many of these cars were equiped with low horespower V8's, but that made peak horsepower at less than 4000 RPM, and torque 2000 RPM or less. So they had the bottom end power to pull along (often just barely), but forget about top end punch.
Smaller engines always ran at higher RPM, but their torque peaks were often much higher. However, they also could run economically at 3000 RPM on the highway (try that with a V8).
My old Olds would plug along at 1500 RPM at 65 MPH with a 2.93 rear axle and OD, but it's torque peak was at 2000 RPM. Even though it was underpowered, it could still accelerate without unlocking the torque converter in OD. My 'Burb does about 1800 RPM at 65 MPH, with 3.42 gears, with peak torque at 2800 RPM.
