Originally Posted By: Captain_Klink
Hi, I have a Subaru Impreza, 2008, with 4 speed ATF.
I just drained and refilled it 3 times.
Do you check it in Drive, with parking brake on? or in neutral? or in park?
thanks!!!
Then how DO you determine how full the tranny actually is?
I'll come to it in a moment...One of the biggest aggrevations or fear , when changing out the tranny fluid is, did you actually put in the required amount??..putting in the same amount as to what came out may not be the correct amount..how many people can actually say for sure that the tranny oil was at its full maximum..I am sure most of us have read or experienced the frustrations of checking your tranny and motor oil levels which results in "doubting" our own work....Checking my tranny oil is done "Cold" the engine "Not" running and useing my own "reference line" further up the dip stick created by useing my "hacksaw"..works well for all the subi's and Vw's in our family...I simply disliked pulling the dip stick a multitude of times and getting different readings all dependent on the various temps of the fluid, motor expansion, and outside temps,etc...it used to take me near 1/2 an hr of highway driving to warm everything up on a hot day and that is with the dip stick "Out" of the tube sitting on the front passenger floor...while everything is hot, I will add or subtract fluid until the fluid is at the top hole on the dip stick..next I went to a dealer that has actually had the probe to check the temp of the fluild and confirmed for me that it was full to the max...next, find a level place to park your car over night with the dip stick taken out for that time..(subis are very sensitive to Not being level.)...To establish if your subi is "level", ..just look at your brake master cylinder,..around the plastic reservior are block shaped designs front and side..line the fluid up with the top of the blocks for example....let the car sit over night to cool ..and then next day insert the dip stick so as to check where the fluid is on the dip stick (tranny fluid cold and engine not running).this being your new reference point...so, before changing out your tranny fluid, check the fluid cold, (add fluid if you have too, up to your own "mark"... then drop the fluid, ..put drained fluid into another "identical" empty container as compared to the new tranny oil container..add or subtract from the new container ..install new fluild..No need to check the dip stick now...and all future tranny oil exchanges are worry free and exact
