I watched this great teardown of a 4L60E and they believe that someone put a bunch of some transmission additive in it by how the fluid smelled, I assume it was some type of stop leak. Just look at how f#%&2d all those seals are.
I don't think it's a fluid with extra seal conditioners, I assume they probably used a cheap stop leak product that uses a petroleum solvent as a seal expander and a lot of it especially if it was noticable in the smell of the fluid.I'm going with there was more in there than just Maxlife. ATP205 maybe or something of that ilk.
I tore down a Ford AOD-E years ago that was that bad, Never did get a straight answer on what exactly was added to the ATF. But I smelled Brake Fluid as well as feeling it in the ATF (It's got a "Hot" feel to it)
What I was surprised about was the 5 Pinion rear carrier in a 245mm 4 cylinder 4L60E.
Guess it would depend on how far you needed to go in for just the seals. I really couldn't see not replacing the wear parts if you're having to be tear it down that far to get to them. For me, it would depend on miles. On any of my cars, at this point, if there were a known seal failure, I'd have them completely rebuilt as well. The labor to get the trans out and torn down, might as well replace parts while you're in there.I also like his videos.
This is also the reason why i always stick to the OEM manufacturer/filled ATF.
The oil has a right amount of seal swell/conditioner in it, there is no need to put extra in it.
When after x amount of year the seals are hardened or brittle the seall swell probably wont do anything but ruin the rest of it, rebuild with only the seals is your best bet.
Most of my mates always go full out with rebuilds and then complain that it costed so much money but 9 out of 10 times it is only a couple euro seal that is needed, no clutches, seals. solenoids, mechatronics etc..
Yes i meant that when youre doing it by yourself, ofcourse if you have to get it done by a specialist you might as well change some extra parts.Guess it would depend on how far you needed to go in for just the seals. I really couldn't see not replacing the wear parts if you're having to be tear it down that far to get to them. For me, it would depend on miles. On any of my cars, at this point, if there were a known seal failure, I'd have them completely rebuilt as well. The labor to get the trans out and torn down, might as well replace parts while you're in there.
