wwillson
Staff member
These leads used to have brushes attached to them. This is what happens when you don't know when to stop cranking. Someone, who shall remain nameless to protect his young pride, was trying to start a 1961 John Deere 4010, which had low batteries. The engine wasn't turning over fast enough for the engine to start, but that didn't stop him from having hope that if he just kept cranking it would start. He said it, "just stopped cranking", then he noticed one of the ground straps from the battery to the frame was on fire.
He took the starter off and I took it to the electric motor repair shop in the next town over. The internals had gotten so hot that the armature needed to be turned and the brush leads where melted and completely separated from the brushes. When we went to put the starter back on, I asked for the picture of the wiring he took before he removed the starter. He looked at me like I had three heads. The starter has two relays and several wires running to it. It took me an extra 30 minutes to figure out which wire went to which terminal.
While we were installing the starter I took the time, patiently, to explain that you always take a picture of something before you take it apart. Then I explained Ohm's law and why batteries with low voltage can still melt things.
I also explained to him that virtually everything I know I learned the hard way, so he shouldn't feel too bad.
