Oils,paraffinic,heavy,solvent dewaxed CAS#64742-65-0
The reason for asking is this is the main component of Valvoline MaxLife, the other 12-22% is PAO's.
"64" in the CAS designation identifies it as mineral oil. Strictly speaking, "solvent dewaxed" is Group I, but if it were then subjected to moderate heat, pressure, and catalyst-driven hydro-cracking, the end product would be Group II.
[ January 13, 2004, 05:30 AM: Message edited by: Ray H ]
That Maxlife is a blend , I did not know
2. COMPOSITION/INFORMATION ON INGREDIENTS
Ingredient(s) CAS Number % (by weight)
ALIPHATIC PETROLEUM DISTILLATES 64742-65-0 63.0- 73.0
SYNTHETIC LUBRICATING OIL 68037-01-4 12.0- 22.0
DETERGENT/DISPERSANT ENGINE OIL PACKAGE
ZINC COMPOUNDS
I think in warmer seasons the Platinum colored bottle of Synpower Engine treatment would mix well with this oil at lower treat rates so to get some Moly and more Ester . The stuff's not near as thick as many of the " STP " like additives are .
SYNTHETIC LUBRICATING OIL 68037-01-4 57.0- 67.0
LUBE OIL ADDITIVE 11138-60-6 6.0- 16.0
ALIPHATIC PETROLEUM DISTILLATES 64742-65-0 2.0- 12.0
ORGANOMOLYBDENUM COMPLEX IN PETROLEUM PROCES 1.0- 10.0
MIXED ALKYL BORATE ESTERS 1.0- 6.0
ZINC COMPOUNDS 68649-42-3 1.0- 10.0
CRUDE OIL HYDROCARBONS (INDISC) 8002-05-9 1.0- 10.0
[ January 13, 2004, 09:08 AM: Message edited by: Motorbike ]
I would like to try the Synpower Engine Treatment, but cannot find it anywhere. Most stores have the Synpower Oil Treatment, but that stuff is thick like STP.
I got the free maxlife. I am going to use the valvoline maxlife engine protector this summer to thicken it up. check the voa on it. it has 479 ppm of moly
