What Toyota do you own? SLL is a 100,000 mile coolant. I wouldn’t flush unless it’s been neglected and I definitely would not use water. The FSM for my 4Runner only recommends a drain and fill. This is what the container says if flushing is needed.
Looks like someone went water only for awhile. I would still do a series of drain and fills using the Toyota coolant. Just try to find a local dealer near who will sell it for $16/gal. It’s gone up $2/gal in the past year.
Genuine Toyota Part # 00272SLLC2 (00272-SLLC2, 00272SLLAC) - Toyota 50/50 Pre-Diluted Super Long Life Antifreeze/Coolant. Ships from Madera Toyota, Madera CA
I pretty much flushed the block and radiator when I had the hoses off and water pump out at no cost with plain water. I may do a few cycles with distilled water after I put it back together, but makes no sense to flush with coolant unless you like throwing money down the drain. I see NAPA has the Peak full strength and they have a Labor Day special at 20% off if you buy a case of 6.
