When new, the clear plastic lenses have a protective coating on them. Unfortunately, sun, weather, etc. and just time tends to deteriorate this layer which rapidly allows the fogging,yellowing &/or hazing of the lens. This is why restoration of the lens is only good for a limited amount of time although protective coatings are available. IMO, this is just another example of a cheap alternative to glass lenses that went bad. Some of the worst cases I've seen are the late 80's/early 90's cars (especially Fords, Subarus and GM trucks.) As for good protective coatings, I'd first check out what the private-pilot small aircraft use on their clear plastic - most of the retail automotive products these days is just more hype and promises.
