What brand of oils do we KNOW work well..........
Bristow, Virginia
My daughters Focus purs like a kitten on <span style="color: #3366FF">Mobil </span><span style="color: #000000">1</span> 5W-20. It seems to really like it, I feel like Im getting every horse available. My Sequoia seems to really like <span style="color: #3333FF">Mobil</span><span style="color: #000000"> 1</span> 0W-30.
Kalispell, Montana
Originally Posted By: JohnBrowning
Now all of the modern Engines Toyota has come out from I4's to V8's will produce single digit wear numbers pretty consistently with any OCI that is 6 months or less and any mileage from 1000-10,000 miles as long as it is in a 6 month time frame. For some reason when people push them to 9 months or longer the wear metals jump up drastically even on that great 4.7 V8 of their's!
I have been running Redline 5W-30 in my 2005 Sequoia starting at 5k and now have over 80k. The only non-stellar UOA I have ever had was on a normal 10k interval that spanned 13 months instead of my usual 6-7 months.
ohio
Valvoline 5w-30 was the only oil my old 1989 Cavalier did not burn. My 99 Trans Am is quiter running on Pennzoil Synthetic 5w-30 than it was on Mobil 1 5w-30. My current Cavalier(2001) and my Toyota Tacoma 3.4 v-6 (2004) run great on Kendall 5w-30 blend <span style="text-decoration: underline">but</span> they run just as well on Mobil 5000, PYB and Havoline. I have never seen a difference in my vehicles gas milage between synthetic vs. conventional motor oil.
Vail, Colorado
Redline and GC 0W-30 run great in my german cars [ especially the BMW's ] M1 TDT / Delvac 1 5W-40 is also excellent I also run Pennzoil Platinum, Eneos, Valvoline Synpower and can find nothing wrong with them... but Redline, GC, TDT are my favorites
dkryan
Cincinnati
Non-stellar in what way? That Sequoia has a V8 in it?
London, ON, Canada
I run GC in the same engine as your I30 (2k Maxima VQ30) and it works great in that engine. I did find though that M1 10w30 works well in the same engine. Car runs awesome on GC though. Have not tried PP 5w30, IMO that is too thin for the VQ. I have seen UOAs posted on Altimas.net for the VQ35 and it liked thicker oil (GC)
Pennsylvania
M1 0W-30 W/M1-110 in my 04' Miata -12K 2-changes per year for warranty M1 5W-20 W/M1-110 in my '06 Civic -75K changed every 5K because it makes me feel good-commuter car, lots of traffic & heat/ac use M1 5W-20 W/M1-104 in my '02 Accord -55K -wife's car, driven less than 5k per year, changed annually M1 10W-30 in my Toro Mower-10 yrs old - changed once a year when I put it away for the winter M1 5W-30 in my Craftsman Snowblower - 2 years old -changed once a year when I put it away in the spring Used Amsoil 10W-40AMO in my '66 Corvair because it was the ONLY oil I could find with (advertised) 12-1300ppm zinc & phosphorous (flat tappet engine) Used WIX 51038 filters-changed once a year. Have NEVER added oil between changes, never needed to. Never had an oil-related problem with any of them. Switched from 5W-30 M1 to 0W-30 M1 in my Miata and the lifter noise at startup (less than 2-3 sec) is now non-existent. I fully realize that with most any of the quality synthetics, PP, German Castrol, Redline, etc, I would have similar results when used with a quality filter, but I can get M1 pretty much anywhere on the road if i need it, The local Advance/Pep Boys/Autozone et al all seem to run it on special, 5qts of M1 & an M1 filter for about $30 on a regular basis, that's $5 a quart and $5 for one of the best filters(IMHO), kinda hard to beat that.
Kalispell, Montana
Yes, it has the 4.7L V8. Non-stellar as in significantly higher iron and copper and a TBN of 0.4.
