What are Two Primary
quote:
Originally posted by Jason Troxell:
thread
diameter
bypass setting
(close, might have to give that one to you)
drainback valve
Sorry, none of the above answers is correct except one might be considered a possible answer, just that it indirectly can mean the same. I'll just go with that.. the actual answer would be Operating Pressure, which if you look at the by pass setting, it would tell you how much pressure it could go before bypass.
Ok, I think I misunderstood then. So what you meant was engine parameters? Such as in designing a filter for an engine from scratch?
In that case I would guess also, operating temperature, flow rate, clearances (tight clearance may need higher efficiency??), intended drain intervals, type of engine, combustion chamber sealing, capacity...
Filtration efficiency - single and multipass - and at what micron rating
Burst pressure of cannister
Backflow preventer presence
area of filtration media
Ok, I think I misunderstood then. So what you meant was engine parameters? Such as in designing a filter for an engine from scratch?more like selecting an oil filter for a specific engine.
flow rate,?
good answer when talking flow rate through the filter
type of engine,
capacity...
I know you were refering to flow rate from the engine but we are discussing filters not engine, so apply flow rate as one of those things to consider when looking at a filter.
HEY I said capacity! And by type of engine/combustion chamber sealing I basically nmeant the same thing as cleanliness level!
If you asked a Fram employee to give the answers to this question, they'd say the following
-canister color
-flashy box with pretty pictures on it
