- Joined
- Sep 2, 2024
- Messages
- 54
When I first got my car new, I was using premium gasoline because it seemed to run better. It was getting expensive and so I tried using regular gas for a while. However when I did, I noticed that I would get knocking/rattling sounds, especially when I was driving up a hill.
It progressively got worse with regular gas and I would get the rattling sound in even more situations. I learned that engine carbonization can cause this knocking and learned about cleaning it off with Seafoam (through the brake booster hose into the engine). It actually worked! After I did the treatment the engine knocked less and decided to go back to premium gasoline to avoid this happening again.
I haven’t had much problem (for the most part) with knocking ever since. The only time the knocking would come back is when I got bad gasoline. I notice that the gas station I use would get good gasoline for the most part but once in a while get a delivery of a gas that would cause knocking. Once I fill up with a good gas, it would go away. The engine would feel perkier also.
My understanding is that the engine should correct itself for the octane level and prevent knocking. I believe the specification for my car (2016 Lexus ES350) allows for 87 octane but my car doesn’t seem to run well on it. It seems many other cars also do not, judging by how often I hear them knocking/rattling.
Is there a component failure, or a common problem that can prevent my car from working with regular 87 octane gas without knocking? Maybe there is a sensor that can go bad?
