I'm new here, but here's my 2 cents... Water/moisture in the crankcase is caused by the products of combustion, one of which is water. Some gets into the crankcase due to blow-by past the rings. When the oil temp gets hot enough the water will boil off. If the oil temp doesn't get hot enough the water doesn't boil off but combines with other compounds in the oil to make acidic compounds. Oil temps are much higher than coolant temps but low 160 degree water stats aggravate the issue by lenthening warmup time. The reason for the 160 or lower stats on marine engines is because raw cooling water is a chemical stew. At temps above 140 F minerals that are disolved in the water come out of suspendsion(undisolve) and tend to buildup in cooling passages. After many hours the waterjackets will look like someone ran some fresh cement thru the cooling system. Closed cooling system use a 180 or 190 degree stat cause they can run a water/glycol mix in the engine.
As for auto vs. marine operating conditions. Marine engines are worked much harder than auto engines. In a car, the engine is highest stressed during acceleration, once cruising speed is reached and the transmission is in Hi or OD the power required to maintain that speed had dropped dramaticly. Boats require consideratle more power to maintain speed because of higher friction and drag. Most marine engines and converted auto engines are designed to be low reving torque makers(less than 5000 rpm) rather the high rev HP makers.
Thinner oils help cool bearings better than thicker oils. Even though they will read lower pressure that thicker oil, more oil is getting to the bearings. As long the oil temp is lower than 300 degrees, the bearing clearances are proper and the pump can deliver enough oil, 5-30 is more than enough to protect an engine when used in a boat or tow vehicle.
Oils specificly for diesel engine do have higher shear restistance to handle the higher loads brought on by the diesels higher conpression ratios and method of combustion. This usnally isn't needed in gas marine engine. Detergent needs are different for deisels too.
[ April 29, 2005, 04:10 PM: Message edited by: jimmbo ]
