Wet / Dry Vac - Overdrive
Scituate MA
5.5 Wet / Dry Vac. Approximately 4 years old. Not used a ton. Recently sounds like it is overworking, way too loud, like something is stuck in the hose (nothing I checked). Filter is newish. Any thoughts?
The ball (it is a like a puck) was my first thought too, and that is what it sounds like. Would the check valve be obvious to spot?
The ball/puck is the valve.
Or the bushings/bearings are about shot in the motor, which is common with these. Mine pretty much go up in smoke every few years and have to be replaced.
