Had a front wheel bearing fail on my tractor. Figured that I better pull the other side apart too. The grease that's in there is dark brown and gooey like stp oil addative. I put the hub and bearings in the solvent tank at work and it just smears it around.
Got the parts soaking in gas hoping that will eat it.
I assume this is original grease Case used in it back in 1956. Wonder what it is?
I'm putting valvoline wheel bearing grease for Ford's back in it since I had it.
