Wearever Brake Shoes/Drums
ON, Canada
I am working on a '76 Chev Malibu that needs rear brakes. Choices are limited but I can get a set of remium Wearever shoes an drums cheaper than Raybestos. The guy at Carquest says he only carries Wearever because they give him the fewest complaints.
I have never used this brand before, any opinions?
I put Wearever pads on my 2000 LeSabre 2 weeks ago, and I am quite satisfied with them.
Previously had Wagner Thermo-Quiet and was disappointed with their performance.
Lol.. he only carries Wearever bc thats their house brand.
Pretty much every drum and shoe you get at a brick and mortar will be from China.. so check NAPA and go with the cheapest..all will be similar
Quote
Lol.. he only carries Wearever bc thats their house brand...….
This is likely true. Wearever is old AAP house brand, and since they now own CQ too, it's their house.
I don't know about the drums, but I put on Wearever front rotors combined with Wagner TQ pads on a Tacoma, no complaints about either. At the time AAP still had significant online codes, so purchase decision based on readily available combined with lowest price.
I agree that most any drum in that tier will be about the same. If you haven't purchased yet and have a little time, besides checking other b&m parts stores worth it to check Rock Auto and Amazon too.
My 92 Toyota pickup needed rear brake shoes, and I bought a set of Wagner Z505(QuickStop) from Amazon. Could not install one side because the pin that holds the brake lever was cocked sideways, or the hole was off some how or another. Tried to drive it home, and it would not seat far enough, so that I could install the C-washer.
Ended up buying O'Reilly BrakeBest Select shoes that are semi-metallic. The linings were a good bit thicker than the Wagner shoes too. No experience with the Wearever shoes, but I can say the O'Reilly premium are top notch.
Get coated drums if any are available. And replace the wheel cylinders too
Oldswagon The guy at Carquest says he only carries Wearever because they give him the fewest complaints[/quote said:
My Carquest guy assured me that they had an exclusive contract to get only high quality Chinese drums and rotors. I bought 2 rear drums for my last Caravan and had to exchange one due to a hard spot on (I think) on the braking surface that caused noise. Those drums performed well. I think that Chinese rotors and drums manufacturing has improved since 10 years ago and I agree with everyone above.
At that age, you'd hope the cylinders have been replaced at least a few times since new.
I have used them many times and was very happy with them.
Thank you for the replies. It sounds like based on what you are saying there isn't much difference between the brands for the brakes available for a car like this. I also checked RockAuto and Amazon and the selection for a car of this age was relatively limited. I found Raybestos, Centric, Monroe, and Wagner along with a few other white box specials.
If there isn't much difference in the quality amongst these Brands, I will likely just go with the Carquest WearEver parts. If I factor in the shipping from the mail order places , the Carquest Parts were actually the about the same as the mail order suppliers. For what it's worth, I have dealt with this Carquest for many years and they used to carry all different brands but only recently switch to WearEver as there only non special order brand. They also have been really good to me for warranty issues over the years.
The only reason I'm doing a brake job on this vehicle is because it needs to pass a safety inspection and the current brake shoes are worn unevenly. The upper portion of the leading shoe is worn too far to pass inspection. The brake drums are the original GM parts and should pass but with the new shoes I figured it was time to replace them. There isn't enough material left to machine the original drums.
Aftermarket brake drums from China are extremely problematic. At least in my experience. The rotors are fine.
With aftermarket drums, regardless of brand, I usually have to order 2-4 pairs before getting 2 drums which are machined correctly. I have had issues with shoes clicking due to a rough finish or the drums being out of round.
If your existing drums are in good condition I would HIGHLY recommend installing new shoes only.
Thank you for the advice. I was favouring buying local over mail order precisely for ease of return and warranty claims. I know you are a big proponent of OEM parts but that's not an option for this car. I could reused the OEM drums but they are pretty rusted and are still fairly worn.
And even if I do refused the OEM drums, they will need to be changed at some point. So is there a viable solution at that point if seemingly all aftermarket parts are cast in China?
Not really - I would just buy local and be aware of the possibility that you may need to purchase several pairs.
For whatever its worth,
installed
05/27/2016 84,325 Brake pads front Wagner ThermoQuiet QC787 Ceramic Disc Brake Pad Set
06/05/2016 84,512 Brake rotors front Carquest Wearever Brake Rotor - Front Part No. YH145287
current miles - 115,069 = 30,557 miles later.
Starting to feel pulsation when braking...........It is likely warping rotors.
I'm looking to replace rotors and pads. May go with Raybestos and Akebono or Honda and Akebono.....
