Thank you for the replies. It sounds like based on what you are saying there isn't much difference between the brands for the brakes available for a car like this. I also checked RockAuto and Amazon and the selection for a car of this age was relatively limited. I found Raybestos, Centric, Monroe, and Wagner along with a few other white box specials.
If there isn't much difference in the quality amongst these Brands, I will likely just go with the Carquest WearEver parts. If I factor in the shipping from the mail order places , the Carquest Parts were actually the about the same as the mail order suppliers. For what it's worth, I have dealt with this Carquest for many years and they used to carry all different brands but only recently switch to WearEver as there only non special order brand. They also have been really good to me for warranty issues over the years.
The only reason I'm doing a brake job on this vehicle is because it needs to pass a safety inspection and the current brake shoes are worn unevenly. The upper portion of the leading shoe is worn too far to pass inspection. The brake drums are the original GM parts and should pass but with the new shoes I figured it was time to replace them. There isn't enough material left to machine the original drums.
