I posted this just as a discussion post. Just for us to share what we think about this guy, his hypermiling techniques and his community of extreme "hypermilers". I will not go as extreme as he does, but I sure find some things very interesting to me and so, I plan to make some adjustments and may try some extreme hypermiling techniques.
I have been reading about this guy for some time now and since I am very interested in hypermiling, I decided to post this thread to see what others think about him and his Guineas Book of Records achievements so far.
Wayne Gerdes is the founder of "hypermiling" and he became famous when he was still driving his Honda Accord. He describes hypermiling simply as "Always beating the EPA ratings in whatever car you own and drive."
Wayne Gerdes, if you aren’t familiar, owns a website called CleanMPG.com. That is the hypermiling forum! It’s a forum dedicated to those squeezing every bit of fuel efficiency possible from their vehicles — also known as “hypermiling.”
Hypermiling is generally characterized by smooth driving and thinking ahead. Thinking ahead helps you avoid using your brakes except when absolutely necessary.
Gerdes' philosophy: "I always drive at or just below the Posted Speed Limit in the far right lane."
I watched this video of his and these are the summary points I got from it
How to Hypermile and get great results. All these info are what he said in the video. I am just posting what he said. It is not be word for word, though, but it is what he says in this video of what he does to achieve what he achieves.
(1) Increase Tire Pressures. Set at maximum sidewall psi. It allows vehicle to accelerate, decelerate and coast a lot easier. For example. Many members of the hypermiling community set the tire pressure in their Honda Insight above sidewall and their tires last them over 100,000 miles. Tires explode at 200psi and more.
36:36-36:55: Waynes Gerdes words; "I run 55psi to 60psi in all my vehicles and get minimal tire wear"
(2) Make sure your air filter is always clean. So, get a brand new air filter every year or as needed.
(3) Oil change with full synthetic and use the recommended weight for your car.
(4) Remove excess weight from the car that you do not need.
Techniques for hypermiling
(1) Speed kills mpg. For example. A brand new Honda Civic hybrid maintaining 35mph in the city will give you 90mpg. Nonhybrid will give you about 50mpg doing 35mph.
(2) Accelerate delicately.
(3) Avoid stepping on your brakes by anticipating what is coming up and your stops. Learn how to drive without needing your brakes except you need it for emergency situations or when it is absolutely necessary to use it. Stepping on your brakes often causes you to lose gas.
Some key points about hypermiling;
(1) You get good results from hypermiling in warm or hot weather
(2) You get great results in city driving than highway driving
