Gate, Globe or Ball: It makes a difference!
Thirty two years ago my brother & I installed an in-ground sprinkler system. To isolate it, we installed a 1-1/4" ID gate valve. At the time I mistakenly thought it would allow the highest water flow. It stayed open 99% of the time because here the ground doesn't freeze and often we have to water even during the "Winter".
FF to a few months back when I notice very green grass around one sprinkler head...and wet ground. I close the big-gate, but water continues to drip. Finally I give it a good twist and the handle shoots loose, sprays me with water and the cut-off is across the yard! I quickly grab a squeeze clamp to force the handle/stem/gate back into place, stopping the leak.
This time I go with a PVC ball valve. (Gotta love a ball valve for high flow, low obstruction, no noise, permanent seal, only 90° between OFF and ON, etc.).
Result? The in-ground inpulse sprinklers have never sprayed farther! Instead of tick-tick-tick they go BANG-BANG-BANG-BANG. Rather amazing to watch. It's obvious they're getting more pressure and volume now than before.
Several years ago I got rid of the globe valve on the HW heater, replacing it with two metal ball valves. When I refitted the water softener, I installed new plumbing with ball valves and unions so I could easily by-pass it or remove it for service, without turning off the water to the whole house. Now I'm thinking I need to do the same for another high flow situation: The clothes washer.
Gotta love ball valves.....
