It's not his carDid you clean the pump screen?
Febi has a less expensive Haldex fluidalways wondered WHY the high cost + if there was an acceptable alternative for the spendy tubes i use for my 2001 TT 225Q
That's what I use. Works fine.Febi has a less expensive Haldex fluid
I change it so frequently that I can't imagine there is much of a difference. So 60 is the newer fluid and 55 is the older? LM has one now too.Febi SDS says group III base oil like the G060 fluid
G055 is Group IV and you pay less and get a full 1 liter container
G060 is the new, more expensive fluid using a lesser base oil. It's more expensive while giving you less product if you buy from the dealership.I change it so frequently that I can't imagine there is much of a difference. So 60 is the newer fluid and 55 is the older? LM has one now too.
Multi-disc Clutch Oil
High performance gear oil specially developed for Haldex all-wheel drive, Quattro and 4motion drives. Provides excellent viscosity and shear stability as well as outstanding friction coefficient under all operating conditions. Protects reliably against wear, foaming and corrosion. Ensures...www.liqui-moly.com
