RI_RS4 made a great suggestion which is that 2.0T FSI owners band together and put together a record of oil analyses. That way, if you choose to run RLI and run into warranty issues, you have some evidence of the performance of this oil relative to VW502 oils. So I have started this process by compiling all of the used oil analyses on FSI engines that I could find on BITOG. You can view the spreadsheet here:
FSI analyses
Sorry, I couldn't figure out how to get the image function to work. Tried several times in the test forum.
I will continue to update this spreadsheet as more used oil analysis roll in. PLEASE PM me when you post a 2.0T analysis. That way, I'll be sure to look for it and record it. Sometimes I'm away and won't check BITOG for a while so by PMing, it helps me not overlook any reports. Thanks.
FSI analyses
