VW 502/505 is based on ACEA "A3" standards for gas engines and the older CMCC "PD-2" standards for diesel engines and also includes the following tests in VW engines:
The VW cam and tappet test, "PV5106" is run in the 1.6L IDI diesel engine. The VW T-4, "PV1449" test is run in the 2.0L Vw gas engine.
VW C+T/PV5106
Test Parameter Test Limit
Applied Load - 1800 Newtons
Scuffing - None allowed
Max Tappet Pitting - 20 microns
Max Cam Pitting - 20 microns
Max Tappet Wear - 100 microns
Max Cam Wear - 75 microns
VW T-4/PV1449 - test duration is 248 hours and no makeup oil is allowed during this test. VW T-4 is considered to be a very severe test for oxidation and thickening....
EOT Kinematic Viscosity @ 40C - 194 Cst max
Viscosity Increase @ 40C - 121% max
EOT TBN, mg KOH/g - 4.7
Ring Stick - none allowed
Piston Merit - 1.0 minimum
Note: "EOT" = End of Test
I should add that VW 502/505 requires a HT/HS viscosity for new oil of at least 3.5 Cp @ 150C/302F. However there is NO requirement to measure this parameter after the test is run.
VW C+T/PV5106
