Hi fellow oil guru's
My friend owns a 1988 Volvo 740 Turbo Intercooled with the 2.3L 4 Cyl B230FT engine,it has 149k on the engine,and the valves are getting a little noisy,mind you not awfully noise,yet it still has good oil pressure,it has what i believe to be 10w30 bulk motor oil changed 2,500 miles ago roughly,and the god evil fram orange can of death which i despise.
I would like to change the oil to 15w40 castrol syntec blend oil to do some cleaning,as my friend cannot afford auto-rx at the present time,and run the oil 1,500 miles,and change it 4 or 5 times,i would like to know if there is a longer version of the napa gold fil1307 oil filter i could screw on the block,as it looks like there is plenty of room,and i am wondering if a motorcraft fl1a would fit,cause the gasket dimensions look very similar,tia for the advice!
Sincerely,
Peter C. Bellantoni Jr
Sincerely,
